Electrical gremlins.
Jonnymoore
Hi all.
can I please pick your brains.
bought a 2008 Voyager 2.8 diesel-unseen. …..anyway lots of electrical issues
none of the clocks work (but has hood message)
radio
windows
horn
interior lights
indicators
hazards
electric mirrors….all unresponsive
the wipers fuse was missing, I replaced it and they run on normal speed continuously, even in the off position. Pulled the fuse again obviously.
the heater controls work front and rear.
the right door mirror will fold in and out….
I have taken apart and cleaned the fuse box (every contact) and every fuse/RELAY
The earth contacts around the fuse box have been removed and cleaned, no issue there.
the car runs and drives perfectly, and no fault codes with a basic code reader.
im guessing some sort of control module or wiring is to blame.
any help would be greatly appreciated.
Yeah.....
I don't know if you are using your phone or not, but if you look at the forum on a laptop, you'll see the dates on replies and sections. The 5th generation is a very inactive section. I used to think it was because they were more reliable than the 4th Gen, which are ruddy awful, but maybe it's because there are so few of them.
Anyway, good luck with it!
