2012 Delta Front Subframe
SMcF
Hi, I think the part you need will be 51804489, but it does depend on what model you have. That seems to be for a 1.4 or 1.6 diesel. And it looks like it is shared with the Bravo. There a a few Delta being broken on ebay and facebook so you may drop lucky. I am not sure on the Delta as it not a failing I've heard of before but on the Alfa 159 the subframes rotted because of the plastic undertray trapping water. I imagine labour will be quite high unless you are handy with the spanners.
Good luck
