Has Anyone Fitted An Aftermarket Dvd Player Or Reversing Camera
darkchild101
Hi there we have a reversing camera on our 2002 GV, but with its own screen, sat it tight to the A pillar on drivers side.
Ours simply wired into the reverse light feed and earth wires for power.
Or are you trying to connect it into the DVD screen? Aftermarket?
I believe they are a bugger to install and work with the Chrysler wiring and wheel controls.
Cheers
Nev
open your boot
there two plastic stoppers by the rear light pull the top  inwards to pull out the plunger then pull the hole plug out
hinge the light out and unclip the bulbs
work out which bulb is the reversing bulb and attach a wire to the feed think its white light green stripe
use that to turn on and power rear camera
