Chrysler Grand Voyager brake problems
galetamix
I introduce myself. My name is Dani. I am a owner of a Chrysler Grand Voyager II 2.5td. I was happy with this car but I have a lot of problems with it. I rebuild the motor, change alternator, shock absorbers, master cylinder, bushes, gearbox cables,... I have changed almost everything. Now I have a problem with brakes. When I push the pedal goes to the floor and the reservoir of the master cylinder split out some brake fluid. I have changed the master cylinder again and after the ABS unit and nothing changes. I checked the prop valve and everything looks fine. I need your help to save my Voyager. Thanks
