My UK 2002 Grand Voyager Diesel now has driver side headlight dipped beam not working, near side OK and both main beams OK. It's not the bulb and there is no volts on the connector. I've pulled off the FCM and nothing looks like a problem.
I've been unable to find on google if there is a separate fuse somewhere for each headlight, but it's not in the IPM under the bonnet.
No obvious wire damage where I can see wires to the driver headlight unit.
Some google results suggest there is no fuse, all done in the BCM, others variously suggest randomly placed fuse boxes under the driver side dash or end of dash, I can find nothing like that. I did find this forum so thought I'd try here.
tstuff
Any ideas?
