Fuel filter and other servicing
Josboogz
Hi
has anyone has experience of changing the fuel filter and worth doing?
if so do you know where to get hold of one and cost of labour to fit?
I noticed it mentioned it should be changed at 70 and 140k.
I think my deltas are due another cam belt change, manual stating every 4/5 years.
what are people’s thoughts on changing spark plugs. I did it a few years back but didn’t notice any change.
Thanks,
I don't think that there is any fuel filter, I think it's pre filtered in the tank and the injectors have a gauze filter, spark plugs are good for 80k, as for the timing belt, I would just change the belt and check everything else (water pump, tensioner and auxiliary belt tensioner bearing)
