Chrysler 300c Re-Flash and restore vehicle configuration
baff57
Hi , i have the above vehicle, the battery went flat for a whileand i got all the lights up and U140e code, implausable data from ABs, i understand this has caused the vehicle to need reflashing and i have also read the FCM will also need restoration to allow the ABS to be Re-Initialised.
I have purchased the Micropod 2 clone and Witech 2 software but can not connect to Stellantissiop with the Micropod as rejecting the WSP serial number as it is a clone otherwise i could peform the flash from there.
So main question is i am in Norfolk UK, does anyone know a Chrysler Diagnostics engineer that can peform the re flash? ie must have Star Scan or Witech sofware with online subscription to Stellantissiop near to me.
Many thanks
Hi Mate,
I had the same issue a few months back, ended up calling round the local jeep dealerships and one about an hour away from me in Exeter was able to flash it for me. Been fine ever since. Hope this helps. Any Jeep dealership should have the right kit but worth calling ahead.
