Does the fuel filter sensor trigger the lightening bolt?
Jock
Hi  ran my scanner over the car after the lightening bolt appeared thinking it would be the throttle body but the only fault showing is the fuel sensor. However my cheap scanner could not find the ABS sensor either so maybe it has nothing to do with filter. I am waiting on parts so once I change it Ill post if  it clears or whether I need to pull the throttle body.
