Chrysler 300C Diesel 58 Reg
BIGMOH300C
A web search on the above error results in many responses:
http://www.justanswer.com/uk-car/83bz1-dpf-is-dpf-fluid-how-reset-dpf-how-investigat.html
To ensure that my wings are not clipped, suggest a search on
p242f diesel particulate filter ash accumulation
but this is a brief snippet of what is on above for quick reference:
P242F - Diesel Particulate Filter Restriction - Ash Accumulation
P2485 - Diesel Particulate Filter Regeneration Duration
These errors codes are saying your Diesel Particulate Filter (DPF) is clogged. I would start by doing a "regen" which will clean out the DPF. See below for the steps on how to perform a regen. If this does not clean out the DPF, your only recourse is to replace it which can run in the £300 range. The DPF is located in the exhaust pipe, and no, it does not require diesel exhaust fluid.
Read more: http://www.justanswer.com/uk-car/83bz1-dpf-is-dpf-fluid-how-reset-dpf-how-investigat.html#ixzz3lclkl8ut
Hope that this is of use
Penguin
