Hi, I’m a Chrysler ypsilon 2013 owner and I recently had an issue with my engine. The check engine and warning lights came on, start stop was showing aa unavailable and the car went to a limp home mode. It turned out there wasn’t enough oil in it (I know, my fault!) so I filled the oil in and the light came off. Two days later, the warnings came on again and it turned out that the oil sump was leaking. I had the car fully serviced, the oil sump replaced, new spark plugs generally a deep car maintenance. When I left the garage, the warning lights were off but came on again half an hour later. I went back to the garage and it was showing that the oxygen sensor had an issue. So I had the oxygen sensor replaced, again did full diagnostics on the car and it was showing no errors. Then I drove around 300 miles with no issues, parked my car on a drive and didn’t use it for about a week. Yesterday I started the car and the engine and warning lights turned on again after less than a minute! I had this car checked 100times now and there are no mechanical faults with it. Could you please advise what the issue could be and how do I sort this out?
Julia
