lirchpin Posted July 27, 2015 Report Share Posted July 27, 2015 Hi i have just purchased a 2006 2.8 crd limited but if it revs to 3000 rpm it cuts out. if i drop into neutral it starts straight away. it normaly only happenes when pressing resume on cruse control but also when over reving in low gears. any idea's please. Quote Link to comment Share on other sites More sharing options...
Penguin2007 Posted July 28, 2015 Report Share Posted July 28, 2015 Sounds like fuel starvation Fuel pump / fuel filter / dirty injectors A good shot of diesel cleaner from your local parts man run it through .... New fuel filter - same place Diesel condensate tank - is it full of diesel or water? Penguin Quote Link to comment Share on other sites More sharing options...
Dizzy Posted April 12, 2017 Report Share Posted April 12, 2017 Hi I know this was an ancient post, but I have a similar problem. Did you ever get to the cause?Thanks I'll be amazed with a reply. Dizzy. Quote Link to comment Share on other sites More sharing options...
soupstone Posted April 13, 2017 Report Share Posted April 13, 2017 What symptoms are you having Dizzy?On both my voyagers, I've had cutting out problems when accelerating. They would cut out under acceleration, and I had to come to a halt and restart.Both times, it was fuel filter issues. In my case, it was a slightly loose housing (on a 2002 2.5, the filter bowl next to the fuel tank) and more recently in a 2006, a renewed fuel filter wasn't tight enough. this filter was at the front of the engine under the bonnet. (2006 2.8). Quote Link to comment Share on other sites More sharing options...
