Low Speed Fans
Dazandtrace
Hi all. I need to know when do the low speed fans kick in. If I put aircon on then I get both fans running on and off. Switch aircon off. Then no fans run untill temp gauge goes over halfway. Should I have fans running low speed any other time. Hope this makes sense
Thanks Daz
8 answers to this question
Hi what is normal range. As this is the first time iv owned one of these. Iv had gauge sit at 3/4 never the red.but that's under load. I have found one problem that I have rectified and that was the rad cap. Iv put a new oe part on seems to have helped. Could there be air in the system iv let car rum with cap off for about 20 mins while hot
Thanks for info
Hi ya well iv done a coolant change plus also had a new radiator as it was blocked. Looks as if that was my over heating problem as car runs a lot cooler even under load.
So I thought while I was at it iv change oil and filter and fuel filter aswell.
Thanks everyone for the advice
