tomada3 Posted July 21, 2015 Report Share Posted July 21, 2015 hi i have v6 grand voyager when i turn right at roundabout get a noise thats sounds likes whistling or a canary singinghow likely is this to be a wheel bearingit only happens when turning right does not happen on straight road Quote Link to comment Share on other sites More sharing options...
0 Penguin2007 Posted July 21, 2015 Report Share Posted July 21, 2015 If its a canary, it may not be a wheel bearing.Wheel bearings are more grumbly stomach after a big curry and a few glasses of lager. It could be the disc rubbing on the brake pads Observing safety all the way ....No head in wheel arch, support car with additional drop safe blocks (a few bricks etc), no feet under car ... Whip the wheel offFull right lockSpin the wheelNoise? Is there a rim of rust on the disc rim?If so - spin the wheel with an old screwdriver / stiff blade placed tight against the brake pad on the disc rimYou may need to do a couple of revolutions to solve. If car is stationary - this may build up as discs get hot, damp and rust forms. Should look at opposite corner as well. My spanner man, has a special tool to do the job - saves him taking off the wheel - but its not cheap and comes from down under - for a Holden. Penguin Quote Link to comment Share on other sites More sharing options...
0 tomada3 Posted July 22, 2015 Author Report Share Posted July 22, 2015 hi thanks have recently replaced pads on rear will have look later could it be pads catching lip on disc Quote Link to comment Share on other sites More sharing options...
0 vvv Posted July 22, 2015 Report Share Posted July 22, 2015 Noises are hard to diagnose in text form on a forum. If the noise only happens when you are turning in one direction then it could be something related to a clearance gap or wear limit when the steering is in that position. Check that the wheel arch liner is securely fixed and not rubbing the tyre. Check the driveshaft CV joints and rubbers for wear and damage. When turning right, this is more likely to be the left (or nearside) driveshaft but could be either. Check the front wheel bearings if the brake disc is moving axially into the caliper pads during cornering. Easy to feel for by rocking and push/pulling the tyres with the front wheels jacked up. If you find free play, check ball joints as well to avoid a misdiagnosis. If the noise is at low speed and on full lock it could be a power steering noise. My guess, without hearing the noise, is that the outer CV joint on your left driveshaft is starting to wear out. If the noise turns to clicking then it's about to break. Quote Link to comment Share on other sites More sharing options...
0 tomada3 Posted July 23, 2015 Author Report Share Posted July 23, 2015 hi took car to garage wheel bearings all ok thinks might have something to do with handbrake shoes maybe springs wearing had offside cv joint replaced 6 months ago have turned car full lock forward and backwood no noiseswill just keep eye on it thanks for you info Quote Link to comment Share on other sites More sharing options...
tomada3
