Electric tailgatre and parking sensors not working
dave62pb
My tailgate is not working. Its like the catch is not releasing. I changed the struts and the control module and it worked tried a few times it opened and closed from the fob   came to use it the next day and it stopped working again.     the parking sensors i tested all ok but still did not work so changed all for a second hand set.  Did not work at first until i moved my caravan then they started to Work.  Disconected the caravan and they worked tested a few times by reversing up to a object all working fine.  Tried the next day they stopped working again.  Do i have to have codes read and reset i have tried disconecting battery but that does not work
