Voyager 2001 Radio Fitting Help
dguest27
Hi there I own a Chrysler voyager 2001 4th gen, I have installed a after market radio, I was advised to use a auto leads pc9-407 connector, I have power to the radio but no sound,I believe my car has the infinity amp in the car,I can see the ground wire for the amp but I dunno what to do from there, if anyone can help will be much appreciated, many thanks in advance.
just done this friday to a mates
in bonnet fuse box  take out the oblong relay nearest the head light
then is used radio fuse as this makes sense keep it all together push a wire in the front connector in the fuse and run it to the relay you just taken out and push it in to 87  front right hole when looking stood infront of car looking rear wards
now amp will turn and off with the key
