emmit Posted May 29, 2015 Report Share Posted May 29, 2015 hello all... just to say hi and hope to be an owner of ..so far an excellent machine One small problem {i hope} the ABS warning light has come on? so i will be working on it to sort it out....anybody who has experienced simular and would know the in's and outs would be appreciated..thank you ...emmit Quote Link to comment Share on other sites More sharing options...
crispinchurch Posted June 3, 2015 Report Share Posted June 3, 2015 by any chance does it go off after a few days of dry weatherif so front wheels off and take off the plastic inner arches 2 screws and a few plastic pull off plastic pinstop rear on body work theres a wire connector from wheels sensor clean it check and solder wires if needed clean the ring with the humps in just behind the front wheel bearing / disk this is abs wheel sensor this has stopped mine coming on emmit 1 Quote Link to comment Share on other sites More sharing options...
emmit Posted June 13, 2015 Author Report Share Posted June 13, 2015 (edited) by any chance does it go off after a few days of dry weatherif so front wheels off and take off the plastic inner arches 2 screws and a few plastic pull off plastic pinstop rear on body work theres a wire connector from wheels sensor clean it check and solder wires if needed clean the ring with the humps in just behind the front wheel bearing / disk this is abs wheel sensor this has stopped mine coming on Hi Crispinchurch ..Thank you for your comments..no it stays on I've had the car for 3 weeks now I after getting a repair manual I have done what you suggest and checked the 2 front connectors for continuity both okay I know this isnt a real test...I have also checked the 2 front sensors and cleaned the rust from both reluctor rings (both where heavily rusted almost bridged across with expanded corrosion ) painstakenly cleaned them to a sqare profile all 47 + 47 of them ..ABS light is still on..I have had delivered today Saturday a cheap OBD11 fault finder ..will try it out later and come back with results..meanwhile I am trying to find a list of faullt codes for the chrysler voyager 2003/2004 2.5 crd se luxe anniversary edition & where can I buy / source those plastic pull off plastic pins..looks like someones been under here before splash guards fixed with chewing gum & baling wire (well almost)Thanks again Edited June 13, 2015 by emmit Quote Link to comment Share on other sites More sharing options...
T14086 Posted June 16, 2015 Report Share Posted June 16, 2015 I would read the fault codes and find out the location/circuit of the fault before guessing here and there. Quote Link to comment Share on other sites More sharing options...
emmit Posted June 16, 2015 Author Report Share Posted June 16, 2015 I would read the fault codes and find out the location/circuit of the fault before guessing here and there.Thank you,update the cheapo OBD tool didnt find any faults so I have ordered a pro obd tool Quote Link to comment Share on other sites More sharing options...
emmit Posted June 20, 2015 Author Report Share Posted June 20, 2015 Thank you,update the cheapo OBD tool didnt find any faults so I have ordered a pro obd toolhi i have found these fault codesU3FF01 LEFT FRONT SENSOR FAILUREU3FFFFF RIGHT FRONT WHEEL SPEED SENSOR SIGNAL FAILUREU2DC501 CAB INTERNAL FAILURE any idea's what i can do to fix them myself ...thank you Quote Link to comment Share on other sites More sharing options...
crispinchurch Posted June 20, 2015 Report Share Posted June 20, 2015 What was the price of pro obdDid you try the key dance. Is turn on and off four times didn't the codes show there on miles screenWas for fixing fault sorry don't know Oskin.RU/pub/chrysler- dodge/manuals Quote Link to comment Share on other sites More sharing options...
emmit Posted June 23, 2015 Author Report Share Posted June 23, 2015 (edited) What was the price of pro obdDid you try the key dance. Is turn on and off four times didn't the codes show there on miles screenWas for fixing fault sorry don't knowOskin.RU/pub/chrysler- dodge/manuals@ crispin thanks for the reply "What was the price of pro obd"...i'm using a borrowed autel MaxiDiag elite cost around $250.00 / £200..."Did you try the key dance"...no but I would really appreciate knowing the key sequence please can you check this link please as all i get is page not found Oskin.RU/pub/chrysler- dodge/manuals Hi all ive managed to clear all airbag and abs codes albiet but one?.. the rt/f/os drivers side sensor shows no signal to cab (abs module no traction control on this voyager..TG)uk model which i am working on now (i have already replaced this once with a used part from fleabay but have put back the org as i was guessing....good calculated guess i thought) i will probably run an a/c voltage check first to the rt/f o/s wheel sensor with both front wheels off and car on axle stands..if that shows no or not within the voltage needed i will check further up to the CAB ...not looking forward to that as it means removeing battery and tray..so i am lead to believe will return in 24 hrs health permiting Edited June 23, 2015 by emmit Quote Link to comment Share on other sites More sharing options...
crispinchurch Posted June 23, 2015 Report Share Posted June 23, 2015 http://oskin.ru/pub/chrysler-dodge/manuals/ put key in and you turn key on so all warning lights come on and off and back on 4 times if no codes it will say done on the screen where the miles and trip miles are Quote Link to comment Share on other sites More sharing options...
emmit Posted June 23, 2015 Author Report Share Posted June 23, 2015 (edited) thank you will try that now do you or any one know the pin out details of the ABS Sensor connector at the CAB Edited June 23, 2015 by emmit Quote Link to comment Share on other sites More sharing options...
