terrymic Posted May 29, 2015 Report Share Posted May 29, 2015 Can anybody tell me how to change the front wheel bearings on my 2008 Grand Voyager.I have a very slight noise from my Left Front (N/S/F) wheel when turning to the right, but have found NO play in the hub. Quote Link to comment Share on other sites More sharing options...
0 terrymic Posted July 29, 2015 Author Report Share Posted July 29, 2015 Job done, tourque wrench, few sockets and spanners or wrenches depending which sde of the pond you live on.Purchased a Haynes manual for DODGE Grand Caravan / CHRYSLER Town & Country, 2008 thru 2012 (Haynes number 30014), the manual differs slightly from the Grand Voyager mainly as no showing diesel engine opyion. Loosened drive shaft centre bolt and wheel/lug nuts, off came the wheel (Left Hand Front), brake housing, disc, disc back plate,drive shaft nut and hub mounting bolts.Removed failing hub and electrics (Slight noise when turning to right and a slight knock when brakes applied hard), and cleaned up hub mounting area with fine emery strip and refit everything in the reverse order.Tighten wheel/lug nuts, bolts & drive shaft shaft nut to correct tourques. Job completed in about 2.5 hours as this was the first time I have changed one of these hubs, if required again would probably take under 2 hours. Caution NO FREE PLAY IN HUB WAS DETECTED on of off the vehicle.Part supplied by Rockauto at a cost of £133.00 including shipping, this is a whole lot cheaper than CHRYSLER dealers here in the UK Quote Link to comment Share on other sites More sharing options...
terrymic
