Chryslercaos Posted April 9, 2022 Report Share Posted April 9, 2022 What is the first thing to check when the abs light comes on? Grand voyager 2.8crd 2004 model. Quote Link to comment Share on other sites More sharing options...
0 maxcaddy Posted April 10, 2022 Report Share Posted April 10, 2022 On 4/9/2022 at 10:40 AM, Chryslercaos said: What is the first thing to check when the abs light comes on? Grand voyager 2.8crd 2004 model. First thing would be to see what others have had with a similar issue, and how they fixed it. For example .... Quote Link to comment Share on other sites More sharing options...
0 Chryslercaos Posted April 12, 2022 Author Report Share Posted April 12, 2022 On 4/10/2022 at 6:54 PM, maxcaddy said: First thing would be to see what others have had with a similar issue, and how they fixed it. For example .... Dear Maxcaddy, Thank you for all of your efforts, it looks like I've got to take off the wheels and check/change the wheel sensers& hopefully this will work as my mechanic tried the scanner and came back as no codes found!!! Quote Link to comment Share on other sites More sharing options...
0 maxcaddy Posted April 12, 2022 Report Share Posted April 12, 2022 Good luck. It's actually not too much of a job to do yourself. Once the wheels are off, it's just a case of getting to the electrical connector under the wing liner and undoing a 6mm (?) bolt on the housing. Assuming the bolt isn't seized/stuck, it's off with the old and on with the new. For the cost, it's worth doing them both as while I was told there was a failure when my light came on, my garage couldn't tell if it were left or right (that was the first time the light came on ~2017, the next time 2021 I just changed the pair straight off). If that doesn't cure it, it could be the rear sensor(s) or an ABS control/pump problem, in which case the repair cost is likely to exceed the value. Quote Link to comment Share on other sites More sharing options...
0 RichardM Posted April 15, 2022 Report Share Posted April 15, 2022 Suggest if you're replacing the sensor check the rotor for corrosion, had to replace the n/s/f sensor for the MOT in December & the rotor's corrosion had built up so much that it scoured the sensor's bottom edge off (hence the ABS light on!) Quote Link to comment Share on other sites More sharing options...
Chryslercaos
