Fameseeker1 Posted April 7, 2022 Report Share Posted April 7, 2022 My voyager 1999 3.3 engine runs OK for a while then it dies. Fuel pump replaced but no success. Following engine stoppage no ignition and pump fuel pressure low . Strangely after about an hour or so ... engine runs perfectly for a while again. Any ideas what to check to resolve the issue? Thanx Quote Link to comment Share on other sites More sharing options...
bignev Posted April 8, 2022 Report Share Posted April 8, 2022 You're in the wrong section of the forum, repost in the Vehicle assistance section fir help! But - wild guess lith limited info, NO ignition could be the coil or its connection failing when hot, certainly if it sits over the exhaust manifold like mine does. I've had 3 coils, but it only failed on 2 cylinders at a time! Quote Link to comment Share on other sites More sharing options...
