Delta exhaust system components - help please
Bertiz
Hello all, hope you're well.
I'm hoping that someone can help me please with replacement parts for the exhaust system on a Delta. I need a back box, "rubber" and a rear strap. I'm told that the cost of the components alone will be north of £400 for original parts. I was wondering if any of these parts are identical to the Bravo parts and also if anyone can help me with product codes and somewhere to source them from please?
Thanks in advance - all input and advice welcome.
Hi, what model do you have? The twin exit exhaust of the 2.0 JTD and 1.75 TB are a pain to get hold of, the single exit exhaust is the same as the Bravo and are about £100 on ebay. The exhaust hangers are also Bravo parts. One word of caution, the rear most hanger is attached by a bolt which often rusts and will snap if forced, then it has to be drilled out and bumper off etc etc. Try to lever the prongs out of the rubber block instead.
HTH
