  • 1
Interior lights
BigCol
Hi one and all. Stumped with this likkle problem of mine, the interior lights in the front don't work. Have checked the Fuses behind the glove box and had the light cluster out to check wiring and if bulbs haven't blown but as far as I can tell everything looks ok. The rear interior dimmer lights work perfectly fine. Has anyone else experienced anything like this and if so did you find a solution. Any ideas or help much appreciated, cheers
Need to check if there is a live and earth at the lamp unit if so you know the fuse and wiring is all OK I'm sure the lamps in the back are on the same fuse check this first
