Sat Nav problems / cruise control problems: after new battery fitted
Penguin2007
I have lost 'stop navigation' in the drop down menu of my 12 plate Delta. (60 kmiles)
Battery fitted by Halfords - because original was down to very few volts as it was sat on drive and not used too much.
Hill start lamp been on for a while - but told not to bother with it as it could just be a small switch under dash / on brake pedal?????
Could it be related to exceptional low voltage?
Will a fault trace pick these up on service?
Any pointers appreciated......
TIA
Penguin
Taken car in for MOT. 24 fault codes have come up! They breed in the system.
The error code worth noting is apparently C1161 Brake switch.  (*)
 Apparently my size 14's had kicked it into a stuck UP position.
(*) If you get someone to check brake lights they are permanently on as well.
Remedied by a rubber stopper on brake pedal switch.
Also solved the speed control / cruise control!
Remember don't put size 14's into the top of the brake pedal.
