Exhaust Sensor
tomada3
hi have 3.3 grand voyager have replaced upstream o2 sensor was fitted by local garage but my car still comes up with fault codes
0134
1036
0138
all these link to o2 sensor got genuine mopar part from chrysler brand new how likely is it that new part is faulty
have unplugged sensor and reset system taking away fault codes but stiil comes up as dtc
has anyone had same problem
thanks
hi i took my car for diagnostic and found the sensor is fine i have a broken wire between connecter and ecu so if i can find the broken wire hopefully fix myself if not autoelectican job
hopes this helps anyone who has similar problem
check my other posts this problem is all related to this wire
