Hi, I'm new to the forum. I have a 2013 Ypsilon 1.2. I hadn't used it for 2 days then went out yesterday. The engine sounded really rough and the engine management light came on with accompanying message that stated the start stop system was not available. Using OBD tester I checked for error codes with none being registered. Any suggestions as to the problem?
vinnierae
