tomada3 Posted April 29, 2015 Report Share Posted April 29, 2015 hi have 3.3 53 reg grand voyagerwhen i drive along and get to 40 mph my car seems to have no power this doesnt happen all the time could be couple days inbetween episodescar is regulary serviced thought the fuel filter was blocked but told by 2 garages its lifetime filter the problem only happens for few seconds and only on open road when i accelerateanyone have any ideas have just replaced both o2 senors my car triggers 0171 code and 0134 codeswhich is fuel system too lean bank 1and upstream o2 senser which has been replaced Quote Link to comment Share on other sites More sharing options...
0 Ben2802 Posted May 10, 2015 Report Share Posted May 10, 2015 The filters aren't lifetime filters they can be changed, diesel one can but not sure about petrol ones, check online with a parts supplier enter your reg and it'll come up with service parts that can be changed. If they can't be changed then they won't sell it, double check with a chrysler garage to make sure. Sound to me like you have a flat spot in the engine which sounds like filter but as its not there all the time I would try to pressure test the fuel system including injectors. Quote Link to comment Share on other sites More sharing options...
0 tomada3 Posted May 10, 2015 Author Report Share Posted May 10, 2015 hi thanks i have used injector cleaner i spoke to chrysler they sell filter so will look into changing that my fuel filter sits on top of tank so have to lower it to replace am gonna speak to garage monday as to regards testing fuel pressure thanks Quote Link to comment Share on other sites More sharing options...
0 tomada3 Posted December 6, 2015 Author Report Share Posted December 6, 2015 hi the problem with my car was intermittant fault with upstream o2 senser earth wire where it meets in the loom with downstream o2 senser the wires meet in loom auto electrican had to strip loom down to find fault as it was intermittant found it to be earth wire then he ran a bypass to the chassis this fixed itmy mpg up by 5 mpg in town 8 mpg on runtook 4 hours to do had to take out battery egr valve to get to loom Quote Link to comment Share on other sites More sharing options...
tomada3
