Possesed Voyager, Gbox In Limp, Electrical Demons Everywhere, Help.....
norbertgolo
Chrysler Grand Voyager 2.8 LX
Hello,
HELP !!!!
I am looking for a talented ​​car electrician or maybe some advice,
Maybe even a wizard because it's my car is probably possesed by spirits ..
My Chrysler spent two weeks in Dashwood Service Centre and they called me to say they can not solve the problems of electric issues and causes so to pick the motor up.......
they recommended a talented electrician ​​to me, but he failed to arrive at 2 appointments !!!!!
I'm beginning to have enough of this,
Chrysler Grand Voyager 2.8 CRD LX. Auto UK
Symptoms
- The lights are working when they want, the light controls dont work
- Overhead control panel turns on only after the car is turned on for around 30 minutes.
- After connecting the battery, without inserting the key, a lot of things like the radio is turned on. HeadTail Lights switched on, so he must disconnect from battery so it doesnt drain.
ps / Special  - Red , GEL battery imported from the United States.
- Indicators and windshield wipers are working not
- Dashboard is working sometimes but no fuel indicator does not work. Either on dash or on OHP, Dash only switches on after a while.
- Auto BOX, not going higher than 2nd gear. Limp Mode
- Error on ODBII which is P0725, Engine Speed ​​Sensor Circuit
From the searches run it can be a bad ground somewhere.
Please help....
Sounds like someone's had a boogie with all the ecu's, everything is controlled by a computer. If the battery is connected the wrong way, even just touching it then removing it, then almost certainly it's fried some of the ecu's. When the battery is reconnected then the, dials spin round, mirrors move and the heater controls re set themselves. It sounds like yours has a complete set of broken ecu's. The fault code is probably one of many, try removing all sensors and connections, one at a time, and clean them up with a bit of emery paper or sand paper and spray with wd40. Could just be a really rubbish connection somewhere that I one has thought of.
