Hvac Is Not Blowing Correctly
smay449
Hi all,
Passenger side is blowing hot air, drivers side is blowing ice cold. Both temperatures are set to LO. Windscreen is perpetually blowing regardless of direction setting (feet, front or demist).
Anyone know if it's the actuator, and if so, what's the solution?
Cheers
It will be the spindles that connect the actuator motors to the direction and heat flaps. They get brittle over time and snap, about £8 each but quire a lot of dismantling to get to. Same as a Fiat Bravo and there are some YouTube videos, much worse if LHD though. Replace as many as you can while it's in bits.
HTH
