Coolant Leak In Car
chuckle1
as the title says I have a leak on the drivers side inside the car. On closer inspection it seems to be leaking from the heater under the dashboard. Is this a big expensive job or could I do it myself? Is it a common problem.? I also need my timing belt changed as I have had the car 2.5 years with out changing it. Can anyone recommend a decent mechanic in the Leicester area aswell.
T.I.A
