One More Question
Madmax
When I change my fuel filter, is the fuel system self bleeding? I.E. Do I just let the electric pump fill up the filter, then turn the key to start. Also if you run out of fuel is it the same?
 On my old cab it was easy as the filter was in the engine bay, and you just had to change the filter, pump in new fuel till the air was out, then hey presto, away you went.
