dave62pb Posted April 9, 2021 Report Share Posted April 9, 2021 A couple of other niggling things to sort outThe folding mirrors don't always work and air con pump cuts in on its own ( have to pull the fuse in winter )Air con works fine when switched on it when I switch off the pump cuts in on and offhope somebody can shed some light on the problem , I have changed relay but still the same Quote Link to comment Share on other sites More sharing options...
0 VoyagerAndrew Posted April 25, 2021 Report Share Posted April 25, 2021 Like you - I have a similar situation with the folding mirrors - one or both will extend too far and then you have to lean forwards and out of the window to pull them back in - it must be an ageing fault - or simply that the lugg that stops it in the right place has sheered off. When these cars work they're brilliant but I think we're beginning to realise why Chrysler retreated from the UK - the voyager range seem to have a 15 year maximum shelf life thereafter drop it as soon as soon as you can to some poor unsuspecting soul. Quote Link to comment Share on other sites More sharing options...
0 maxcaddy Posted May 24, 2021 Report Share Posted May 24, 2021 Aircon pumps cutting in even from cold even though the Aircon is off isn't a fault, it's what some system do. I don't know why and can't be asked to find out, but when you least expect it, the compressor cutting in/spinning up is OK, it certainly happened all the time on my Explorer, which I had for 10 years with excellent Aircon that never had to be topped up. "the voyager range seem to have a 15 year maximum shelf life thereafter drop it as soon as soon as you can to some poor unsuspecting soul." Maybe 15 year max, but I would say 12 - 15 years typical, and maybe some of those 'poor unsuspecting souls' are now posting on here . Quote Link to comment Share on other sites More sharing options...
dave62pb
