dave62pb Posted April 1, 2021 Report Share Posted April 1, 2021 I need to remove the plastic panels to gain access to rear washers as think the pipe is blocked or split anybody know how the panels are held in place , as I don't want to break any clips or mountings Quote Link to comment Share on other sites More sharing options...
0 bignev Posted April 1, 2021 Report Share Posted April 1, 2021 If it's a stow n go version lift the carpet on the right hand side of the rear well and find the washer tube, apparently fairly common for the tube connector to come apart there - mine had - so no fluid to the screen but the motor worked and the carpet got wet !! Of course there may be a joint there on the normal version too, but I don't know about that! Quote Link to comment Share on other sites More sharing options...
0 dave62pb Posted April 4, 2021 Author Report Share Posted April 4, 2021 Yes its stow n go , cant see how to get 1/4 panel off and didn't want break anything Quote Link to comment Share on other sites More sharing options...
0 bignev Posted April 4, 2021 Report Share Posted April 4, 2021 You don't need to take the panel off, just gently but firmly pull the carpet out from under it, after removing the back edge trim. That takes a very firm tug as it's fixed with push in clips, but check the centre in case I forgot about any screws next to the latch! Quote Link to comment Share on other sites More sharing options...
0 dave62pb Posted April 9, 2021 Author Report Share Posted April 9, 2021 You don't need to take the panel off, just gently but firmly pull the carpet out from under it, after removing the back edge trim. That takes a very firm tug as it's fixed with push in clips, but check the centre in case I forgot about any screws next to the latch!Thanks , done what you said , found the joint had come apart , washer working now , a 10 min job that I have not got around to for a few years now bignev 1 Quote Link to comment Share on other sites More sharing options...
dave62pb
