I have a Voyager 2.5 CRD (2003). It has just failed its ITV (Spanish MOT) for excessive white smoke.
I decided to change fuel filter and also, while under the bonnet, noticed that one of the injectors seemed to be getting oily and, on closer inspection, when turning the car off, I could hear it 'gasping', so decided to replace the copper washer and rubber seal on the injector.
I have got the injector out, cleaned the bore and re-faced the mating face on the head.
I have a couple of questions:
1: When changing the copper washer, does the new one need to be annealed?
2: I read that the mounting bolt for the injector clamp should be tightened to 32.4Nm, does anyone else think that seems a bit high?
Anyone ever stripped the thread or sheared the bolt?
VoyagerPig69
Happy New Year to you all.
Thanks in advance for any replies.
