Egr Pipe/exhaust
brit644
Hi all.
Had exhaust fumes in cab [initially thought webasto] Found it to be a short stainless steel pipe from egr returning to engine/exhaust. It's very sharp return. its only maybe 1mm thick and maybe 7cm diameter.
Anyway mechanic welded the break/crack, its at the flange'd end. To be honest looks like a design fault to me. Anybody know the name/part number...and if you can actually get them... as the weld changes shape slightly.
Also smoke on first start up in the morning. This has just started, drive half mile and and its gone. Mechanic says its diesel??
Tks in advance for any help
