Selling Advice
Garethm
Hi from formerly known as Buiscuit (long story don’t ask) any way my Voyager is going up for sale and can I have any advice as to what to ask? It’s an ‘05 with just under 80,000 miles on the clock head gasket, water pump, thermostat done 2years ago. Had a new rad, inner tie rods, outer tie joints, new struts plus bearings and top mounts plus new battery, anti roll bar bushes and links done this year. Black bodywork in good Nick, failed mot on abs light, no signal from ofs wheel, new sensor hasn’t worked. Lovely to drive but got to go.
Hi Gareth, I know you are selling it and that's the main point, but I'm just asking if the condition of the teeth on the shaft that the sensor looks for was checked? Our first 2002 GV had that. Not getting the right readings. But you stated NO signal so more likely cabling fault.
Teeth on the ABS castle ring should of course be all intact and clean. The sort of important bit here thats often not checked is the clearance between the sensor and the castle ring. Clearance, really technical here, is a fag packet box..Think thats around 0.022in (22 thou). Metric minds can work that one out..
