spressler Posted August 26, 2020 Report Share Posted August 26, 2020 I'm looking for someone who can come and look at Grand Voyager that wont start. Not battery or alternator. Key not talking to ignition? PR7 area. Quote Link to comment Share on other sites More sharing options...
Brian1964 Posted September 8, 2020 Report Share Posted September 8, 2020 What I would doDisconnect the battery completely Put the battery on charge over nightThis would also reset the TIPM After charging reconnect the battery The reason for this, you may have a grand fault which caused battery drain This happened to me I had wipers come on by themselves when off.Dash cluster lights wouldn’t go off.Window wouldn’t go up Fault- Blind Spot ModuleGot them replaced with Mopar Genuine parts from Rock Autos.com now it’s perfect Quote Link to comment Share on other sites More sharing options...
Brian1964 Posted September 8, 2020 Report Share Posted September 8, 2020 You said not Battery or alternator fault So when you put the key in ignition, you get nothing at all Try looking the doors from the outside with the key Then open the doors, put the gears into drive then pack in park. Then try and start the car Quote Link to comment Share on other sites More sharing options...
