Headlight Adjustment?
riber3
Hi there,
Can anyone please tell me if its possible to adjust the horizontal aim on a 200 Grand Voyager? I have found the vertical adjustment torx screws but cannot
see anything for adjusting from left to right?
Additionally is there anything like a switch to make change over to European Driving or is just a case of fitting beam deflectors?
Any help would be welcome
I've a 2003 model and there is two adjusters on the actual headlight unit.
Beam deflectors I'm afraid, but certainly wouldn't take long to swapover the other light units if you had a set.
Many thanks for your reply I have seen the height adjustment screws in the top for up/down adjustment but nothing for side to side as yet so I will have a closer look today as my drivers side is pointing too far to the right
