Rear Washer Hose Location
Liam89
Hi all, the rear washer jet isn’t working but I know the pump is. I pulled the carpet back on the drivers side which is where I assume the hose is but it’s all encased in plastic and some things seem to go off in to the middle of the car, however I then can’t trace them. Do they go under where the middle seat storage? Or am I looking in the complete wrong place?
If you are stow n go mine had a connector come undone in the well at the rear drivers side, I had wet carpet when the washer was used but dry rear window!!
Just pull the carpet out from the rear corner - carefully of course! I can't remember if the back plastic boot trim came off to make it easier, but that does pop out and clip back in.
