Hi Everyone.
Garyfox78
  • 4 weeks later...
Hey, thanks for the reply. No not changed the wires just the plugs. Without getting a code I'm a little wary about just throwing money and parts and still not curing the problem. Been looking around the forums and torque converter rumbles seem to be a common problem with similar symptoms. Are the sparkplug wires the same thing as coil packs? They can be ohm tested to see if faulty,
correct?
Gary
