Park Assist Issue
clarkster72
Hi Everyone, New to this forum even though had my 300c SRT8 for over 8 years.
My Rear Park Assist is Dead, no lights or sounds even on initial key turn. Won't toggle on/off in EVIC, just states ON. No warnings on EVIC either. I suspect it could be my Park Assist Module. Anyone had similar issues? Does anyone near me in the North East have a spare Module I could try before buying a new one? Part number is 04602421AF.
Any help would be appreciated.  :)
A while ago my reversing sensors were playing up. The lights would come on randomly and it would beep when I was driving forward. On another post Briscoe76 put the below info on. It fixed the problem and also sorted several other electrical gremlins I had... radio playing up, speedo needle randomly waving about, indicators missing a beat, random warning lights. Give it a go, it's the best tip I've read for years.
PS: Really envious that you have an SRT8.
Briscoe76
Hi, did you get this problem sorted at all?
If you didn't, then its an easy fix. Open the bonnet and, and find the washer bottle. Next to that, bolted to the drivers side wing, you will find a black box. Unplug the box, and hey presto, the fault will vanish. It will also cure a few other faults, such as indicators that miss a click, rear wipers wiping on their own, reversing sensors firing up when your driving forward.
The box is the HID translator module. All it does is let the ECU know when a headlight bulbs blows. If you can live without that function then you can cure all the rest!! The HID module develops a fault, and effects lots of other things down the line.
Edited by BrownSugar
