Window Stopped Working
Sentech
Quick update on this, I finally decided to investigate. Removed the three screws securing the door panel, gently levered of the panel, removing the clip on the door release and the two electric plugs, Removed the weather sheet gaining access to the power window.mechanism, one gentle tap of the motor with a plastic hammer and BINGO jobs a good 'un. Twenty minute job.
Years ago I had similar. Weird one. I went to car wash HP Lance's lad on rinse pointed his Lance down vertical. Noticed dozens of tiny black platelets /flakes of carbon flying up vertical.
Tried window on way home for the millionth time. Window worked ever since.
Take care.
