Dead Remotes On 2007 Grand Voyager
Mopar666
Hi all , I’ve owned this car since it was 9 months old and apart from a rebuilt auto transmission the car has been very reliable , but now it has a couple of faults with from looking through the posts on here seem to be quite common , first is the ABS light is on , changed both front sensors and the control unit , the other is both remotes will not operate the car, everyhing else on the car works perfect , looking like the BCM ,?are these plug and play of do they have to be “added” to the car ? Any advice greatly received Edited by Mopar666
Hi there!
Don't know any background, and it would be better in the vehicle assistance section, but have the reluctor rings, for the ABS sensors to see, on the drive stub shaft been checked?
And I presume you mean both remotes have stopped working. If so initially have the batteries been changed? After that pull out the IOD fuse for half an hour to do a bit of a reset.
Cos hell no a BCM is very much not plug and work, not a chance.
Edited by bignev
