Starting Problem
Boboski
Try to bump start it/ tow  if it starts chances are the starter motor  get it checked out  Don't try to bump start if it an Automatic
Do you hear the solenoid click when you try to start??   mech should be able to ascertain if the power is getting down to the solenoid on the small wire on the starter?? there is probably a starter relay in the system could be that  check the manual     not normally a fuse in that system  but not sure.
Could also be the ignition switch but a mech worth his salt should be able to sort?
best of luck!
  • 2 months later...
Hi there!
Welcome!
Just some basic stuff - have you put a multimeter on the battery to check voltage?
It should be above 12.7 volts for a good battery.
It's usually better to post questions in the vehicle assistance sections as not everyone check in on the newbie section, as it's often just a hello message kind of thing!
