Sentech Posted February 11, 2020 Report Share Posted February 11, 2020 Hi guys, I need some advice. The Red Handbrake warning light has started illuminating and giving a "Ding" when it does. This is intermittent but is becoming more frequent. Any tips, thoughts or solutions ? Chris Quote Link to comment Share on other sites More sharing options...
0 QinteQ Posted February 11, 2020 Report Share Posted February 11, 2020 Adjust. Leedsmans thread with photo's here: https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/my-struggles-gv-handbrake-mot-22210/ Quote Link to comment Share on other sites More sharing options...
0 bignev Posted February 11, 2020 Report Share Posted February 11, 2020 Have you been under the bonnet and checked the brake fluid level? Quote Link to comment Share on other sites More sharing options...
0 QinteQ Posted February 12, 2020 Report Share Posted February 12, 2020 Sentech Your car started. Wheels facing forward. STAND on footbreak. 6 good Yuk's on Hand Brick. Will equalise Y cable and clockspring. Light out ? If not you may have bad wheel sensor reading. Best of luck. Quote Link to comment Share on other sites More sharing options...
0 Sentech Posted February 14, 2020 Author Report Share Posted February 14, 2020 Thanks for the inputs. The fluid level is spot on,and the vehicle sailed thru its inspection less than a month ago. I'll check out the other adjustments recommended this weekend and give an update. QinteQ 1 Quote Link to comment Share on other sites More sharing options...
0 bignev Posted February 15, 2020 Report Share Posted February 15, 2020 I know you say the fluid level is spot on, but is it at the top? The warning light is also for low fluid, so if it's intermittent it may be moving fluid, just my thought but if it isn't already bring it up to max, and if the light coming on is "repeatable" under circumstances you know, then maybe fix the float up and drive it to see if it comes on at that. Or is it the handbrake switch become loose? And moving and coming on when the lever is fully down? Quote Link to comment Share on other sites More sharing options...
Sentech
Hi guys,
Chris
