Voyager Lx 3.3L 2003 Dtc Codes
JaySurrey
Hi all,
I was just wondering if anyone could help me.....
Bought a lovely Voyager secondhand about a month back and after 2 weeks or so driving it the engine light has come on and will randomly go into limp home mode (2nd or 3rd gear) if we pull over and restart the engine it seems to be ok for a little while but then goes into limp mode some time after!
I rang around and found a guy who plugged his diagnostic machine in and read the codes to be the following:
24 Hydraulic pressure test failure
Chrysler DTC Code: 32
SAE Trouble code : P0845
i daren't take this beauty to the Chrysler garage as we are very limited on funds at the moment and at £150 an hour this is something i simply cannot afford at this present time! (We have just replaced gearbox and clutch on our other vehicle!)
Now is this 2 separate issues, or one issue? (DTC code and SAE code)
the guy who popped over said just to replace the Solenoid pack, but i am dubious on spending £200 if it doesn't solve it!
Anyone????
Hi Jay
Be cheeky - ring a Chrysler dealer and say that you have been told that the vehicle has been on a check-o-computer and has come back with the following codes ...... It could be a lucky Green Flag man or the AA man or even an RAC person.... with a computer that has Chrysler codes on it....
Ask them for a remedy, I'm sure that they will want your custom  :D
You then have your answer
Saves on you facing them face to face, and then dive into a local garage (or your own if confident) to fix
:rolleyes:
Penguin
