roadhog Posted April 22, 2014 Report Share Posted April 22, 2014 Hi all, Just came back to my car and someone has bumped into my Grand Voyager and broken the rear light lens. Are these easy to replace? and can I replace just the lens? Quote Link to comment Share on other sites More sharing options...
0 a1ant Posted April 22, 2014 Report Share Posted April 22, 2014 Hi and WELCOME TO THE FORUM Sorry to hear that someone has damaged your Grand! Unfortunately the lens is not replaceable on its own, and you will need to replace the whole unit. Fortunately this is a very straight forward job and you should be able to save yourself some money by doing it yourself. In order to remove the rear light, raise the tailgate (boot). You will see 2 x 10mm bolts at the boot side of the light unit. Undo these two bolts. Then, pull the whole light unit straight back towards you. There are two rubber locating lugs that hold the light into the rear quarter panel and these will "un pop" as you pull the light straight back. Then simply disconnect the wiring multi-plugs and remove the unit, Hope that helps, Alan ben and roadhog 2 Quote Link to comment Share on other sites More sharing options...
0 roadhog Posted April 22, 2014 Author Report Share Posted April 22, 2014 Hello, thank you for your reply! It sounds easy enough. Where is the best place to get a new light unit from? Quote Link to comment Share on other sites More sharing options...
0 a1ant Posted April 22, 2014 Report Share Posted April 22, 2014 Hi mate, As of yet I am not aware of any of the usual after market outlets selling after market rear lights. Therefore your best bet is to go direct to your local friendly Chrysler parts department! If you have any trouble fitting, just post back and one of us will be able to assist! Alan roadhog 1 Quote Link to comment Share on other sites More sharing options...
0 supercollider Posted April 23, 2014 Report Share Posted April 23, 2014 Can you not get them from good old fleabay ? Quote Link to comment Share on other sites More sharing options...
0 a1ant Posted April 23, 2014 Report Share Posted April 23, 2014 Hi, I'm sure it is possible to get hold of second hand or unused new light units on places like eBay etc, however a quick search of eBay I've just done didn't reveal any for the 2008 on model. Plenty for the earlier voyagers etc though. I'm sure as time goes on they will become more readily available.. Alan roadhog 1 Quote Link to comment Share on other sites More sharing options...
0 roadhog Posted May 5, 2014 Author Report Share Posted May 5, 2014 Hello! Just a quick update. As you say I couldn't find an aftermarket light unit anywhere so bit the bullet and ordered one from Chrysler! It wasn't cheap but I saved enough money by fitting it myself and also didn't have to claim on insurance! So I'm very happy. Quote Link to comment Share on other sites More sharing options...
0 a1ant Posted May 5, 2014 Report Share Posted May 5, 2014 Hi mate, Glad you got it sorted in the end! Alan Quote Link to comment Share on other sites More sharing options...
roadhog
Hi all,
7 answers to this question
