Clutch Assy Delta 1.4 Multi Air
poopydog
hi  bud, cheers for the quick reply. I received a call from my garage stating a  price  of around £248 just for the parts. I did a quick search as the vehicle was already booked in.
caar parts came  out at £188.75 inc vat but then I found the Luk site, also searched the shop4 parts site which identified the part as fitted to the  punto Evo, there were asking £106.97 plus vat.
All sorted now.
While im here........Epic motor, just so different, approaching 58,000 miles. New clutch fitted today, timing belt/ water  pump etc fitted today also. New  oil and filters, new g/box oil, new plugs.
Never had an issue with this vehicle apart from consumables, pads/discs etc.
What concerns me  is the rarity and  possible further costs with this vehicle eg previous posts £450 for back box when a Brava box will do!!!  If your not  in the know somewhere along the  line your gonna get ripped  off because
once the part has failed and your  in the garage its a bit late to do the research.
A few things about clutches and the Delta
The clutch kit is 2 piece as The release bearing is concentric and is combined with the slave cylinder and expect to pay around 50 for this alone,.
There is also a dual mass flywheel fitted which can be around 350 to replace
The actual clutch would be equivalent to the Bravo and Punto T-Jet engines
Edited by Andrewgrale
