Seat Configuration
Mfcfan
Hi all,
I have a 2003 grand voyager (pre stow and go).
Has anyone managed to find a way of having 2 single seats on the back row as opposed to the bench?
The mounting points are the same and I can get the centre NS seat to mount to the rear OS and vicaversa but not to seats together at the back.
It seems pretty close to fitting them both in but the arm rests and cup holders seem to block them from fitting.
Hopefully someone has found a work around for this.
Thanks in advance
Hi there!
Yes it would seem that you can fit the 3 seat bench in the middle row, but not both captains seats in the back - or even on the correct side for the seat belt as you have described.
I didn't try removing the arm rests, as I was only curious, I didn't need to do it.
