phildsharp Posted December 20, 2019 Report Share Posted December 20, 2019 Hi, I've just replaced my radio after the screen went blank. Bought a replacement Becker radio off Ebay, complete with code, operating manual, and FM antenna. Fitted the replacement unit (didn't replace the FM aerial module), entered code OK. New unit powers up, all information shows on screen, but zero sound coming out on radio or CD/DVD. Although the previous unit had a blank screen, CD's still played so I guess this rules a problem with the amp out. Any advice, please? Quote Link to comment Share on other sites More sharing options...
0 ametcalfe1989 Posted January 1, 2020 Report Share Posted January 1, 2020 This is probably not going to be of any help but I tried doing the same thing a couple of years back and got the same result!Apparently, it's something to do with the infinity system but I could never work it out so I gave up and went back to OEM. I hope for my sale and yours you find the answer! Quote Link to comment Share on other sites More sharing options...
0 Dazzer Posted January 6, 2020 Report Share Posted January 6, 2020 Hi m8 I changed mine and same prob so I had to find the amp that was in the rear off side wall right at the back and disconnect it then connect all the wires back together but it's a time consuming job as the wires don't go to the same colours but I did it in the end so good luck m8 but it is possible Quote Link to comment Share on other sites More sharing options...
0 QinteQ Posted January 6, 2020 Report Share Posted January 6, 2020 Hi, I've just replaced my radio after the screen went blank. Bought a replacement Becker radio off Ebay, complete with code, operating manual, and FM antenna. Fitted the replacement unit (didn't replace the FM aerial module), entered code OK. New unit powers up, all information shows on screen, but zero sound coming out on radio or CD/DVD. Although the previous unit had a blank screen, CD's still played so I guess this rules a problem with the amp out.Any advice, please?This ex regular is electronics trained, here is his blog. http://www.thebmwz3.co.uk/2017/12/chrysler-audio-system-amplifier-and.html?m=1 He put a flip up AIO in his GV, I've sat in it, seen it installed and working. Quote Link to comment Share on other sites More sharing options...
phildsharp
Any advice, please?
