Omegalow Posted October 18, 2019 Report Share Posted October 18, 2019 Evening, apologies been neglecting site for a while back in with the 300c and i am running at a loss. Any guidance help or info widely appreciated Car starts and runs However it appears to be in limp mode, slow to rev slow to drive No smoke or surges. Just really dam slow. Fault codes comes up time and time again U1008Lin bus 1 is shorted to ground or earth. 3.0 CRD 2006 Way under powered. Is the fault code the cause again its described in so many different ways. Please help before i pull my lack if hair out! ? Quote Link to comment Share on other sites More sharing options...
0 Omegalow Posted October 18, 2019 Author Report Share Posted October 18, 2019 Just a update as well i have 2 other codes showing U1409 Implausible left front speed signal receivedU140C implausible right rear speed signal received Cars reving right up to 3600-3700 rpm before changing gear. And feels like lack of power Quote Link to comment Share on other sites More sharing options...
0 Eightpint Posted November 26, 2019 Report Share Posted November 26, 2019 Hi, the two bottom codes will be to do with the relucter rings on the wheels, or the actual cable/sensor wire damaged to the wheels A common problem with these cars is that the magnetic rings rust on the wheel bearings so the sensor can't read the speed from that wheel, this in turn puts the car in limp mode. You can buy the rings and sensors separately but might be a better idea to change the bearing at the same time, but before you do any of that check the sensor cables from the wheel to see if they're damaged. Quote Link to comment Share on other sites More sharing options...
Omegalow
Car starts and runs
