Starting Problems
Mrsslithers
Hey I have a 56 voyager. It's been a bit iffy to start for a while. Last night it decided that it wudnt start and I'm getting nothing when I turn the key.ive tested the battery and that's fine and I'm getting lights etc.i checked the selonoid on the starter by running a wire from the battery to the starter and it still isn't starting. My dash needles go mental when I turn the key. Any ideas on what to do? Does it sound like I need a new starter etc
Hi there,
Small point but the post is in the wrong section, yours is a 4th generation, 56 plate is 2006 / 2007.
I would reckon the battery, I read you said it's been tested but it sounds like a battery. Try it with a jump start from another vehicle with its engine running.
What voltage did you get on the test? 13 volts or over is ok.
Also is it petrol or diesel?
